[solved] DTL_CEL/partran/cli segfault
Norwayyngvelevinsen
Norway (no)
Norway
Post by Norwayyngvelevinsen »
I have a DTL lattice I tried to run using the CLI (noX11) on Linux, but I get a segfault. I manage to make a minimal example attached.
It looks like if I use QUAD instead of DTL_CEL then it does not fail. It also seem to only fail when partran is turned on. Finally it works fine if I run in GUI, and it works with older CLI versions (not sure when this issue started).
The output I get is:
   Multiparticle calculation with PARTRAN
  Element :1  [0.00000 m]  Ngood :100000
 [ 0% ]
QVariant::load: unable to load type 64.
QVariant::save: unable to save type 'QFont' (type id: 64).
Critical system error:
Segmentation violation
lattice.min.dat
(165 Bytes) Downloaded 508 times
DTL.min.ini
(43.77 KiB) Downloaded 470 times
Last edited by Norwayyngvelevinsen on Wed 15 Mar 2023 07:31, edited 1 time in total.
Norwayyngvelevinsen
Norway (no)
Norway
Re: DTL_CEL/partran/cli segfault
I can add that e.g. version 2.20.0.0 seems to work fine, maybe that helps narrow down what changed.
Dear yngve,
It's fixed.
Norwayyngvelevinsen
Norway (no)
Norway
As always, thanks for the prompt response. I checked the 2.21.0.0, but I still get segmentation violation?
% ../TraceWin project.ini hide_esc
   Data Reading...
 Reference particle transports in Elements: 1
 Reference particle transports in Elements: 2
 Total Line : 2 Elements
  Calculation of line envelope
   : finished
  Number of step : 35
  Memory used   : 1 kBytes
  New Data file writting :
  /storage6/public/TestTraceWin/mini_dtl/calc/lattice.dat
  New Data file writting (with detailed DTL_CEL):
  /storage6/public/TestTraceWin/mini_dtl/calc/lattice_2.dat
% ../TraceWin -v
Current version: 2.21.0.0
Fast maybe but not very efficient and rigorous :?
In fact, there were two errors that accumulated and when I corrected the first one, I didn't even test the specific case that you had given me.
So it should be good now, I hope and I didn't change the version.
Norwayyngvelevinsen
Norway (no)
Norway
Thanks Didier, now it works again! :)
