Dose the envelope contain the dispersion effect?
ChinaZhaoliangchao
Post by ChinaZhaoliangchao »
When I plot the beam envelope in 'Envelope' mode, it looks like the envelope does not contain the dispersion effect. But in 'Partran' mode, the dispersion effect is shown in the envelope.
So, does the envelope contain the dispersion effect (in "Envelope" mode) ?Or, how to enable it?
line1.dat
(859 Bytes) Downloaded 572 times
line1.ini
(43.77 KiB) Downloaded 548 times
dispersion function.png (39.01 KiB) Viewed 9206 times
plot in partran mode.png (53.99 KiB) Viewed 9206 times
plot in envelope mode.png (62 KiB) Viewed 9206 times
Re: Dose the envelope contain the dispersion effect?
Dear Zhao,
The dispersion effect shown in the partran is due to input energy spread you have defined to 0.6 MeV. In envelope mode, your beam iis defined as CW, no spread can be considered.
If you want to have something similar you have to defined beam like following picture. Its not exactly the same input energy spread, but by this way envelope and teacking will be the same.
ChinaZhaoliangchao
So it is. Thank you.
Best regards
