Beam matrix (or its elements) along the channel
GermanyRubin
Germany (de)
Germany
Post by GermanyRubin »
I can see a beam matrix in a chart window for each separate position.
Is it also possible to get a file with beam matrix behind each element in a channel (similar to transfer matrix file)?
Or even better: get a data for certain beam matrix element M(i,j) along a channel? ;)
Thank you!
Best regards!
Re: Beam matrix (or its elements) along the channel
Dear Rubin,
In the files "partran1.out" (tracking) or "tracewin.out" (envelope) at each step you have all the first and second order moments, as well as the emittances & SigmaXY and SigmaX'Y'. Isn't that enough for you?
GermanyRubin
Germany (de)
Germany
thank you for the answer!
The problem is that I need <xy'> and <x'y>.
Best regards!
Anna
Dear Anna,
If I add <xy'> and <x'y> to the*.out file, is that enough for you?
GermanyRubin
Germany (de)
Germany
Thank you very much!
Dear Anna,
2 new parameters have been added to the *.out files to suit your needs.
