Match using diagnostics issue
FranceEmmanuel
Post by FranceEmmanuel »
While I'm doing an optimization with envelopes only first using "Match using diagnostics", I noticed that when I tick the "with PARTRAN" check box, the enveloppes then go wrong.
For the reason that for achromaticity optimization, I use the envelopes optimization results for particles simulation, I uncheck the "with PARTRAN" option first. Then I check it again for other optimizatiions along the line. But while I do this, the envelopes go wrong for envelopes mode, whereas envelopes for particles mode are good.
There is no other change.
Thank you for your help.
Emmanuel
Re: Match using diagnostics issue
Dear Emmanuel,
Yes, this is normal behaviour because there was only one reference accelerator design in the code used for envelope and tracking simulations. I've made a few changes to try and work with two distinct designs. This should improve things, particularly on the example that you point out, but the work is much more substantial and further in-depth changes will be needed to better distinguish the 2 machines set up for tracking and envelope.
FranceEmmanuel
Thank you for the explanation.
Looking forward for the update.
Emmanuelm
Dear Emmanuel,
The upgraded code is already available on our website
Dear Emmanuel,
