Einzel Lens
- Initiated
Einzel Lens
Please explain little more about TRANSVERSE defocal for electrostatic acceleration, There are two units mentioned eV/mm2 and eV/m2 on page 55 and 108. I have to use this option to define an einzel lens.
Re: Einzel Lens
Dear Sarvesh,
In my manual, both are in eV/mm2, probably you should upgrade your code to get last one including last documentation.
- Initiated
Re: Einzel Lens
ok thanks, so it is Energy of incoming beam (eV)/Aperture(mm2) = Transverse defocal ?
- Initiated
Re: Einzel Lens
Can you elaborate what is delta s (mm) mentioned on 138 page no. what is its value when manually verifying the transfer matrix of one electrostatic acceleration line. It will be helpful if you can make a drawing depicting the various dimension mentioned for it?
Re: Einzel Lens
Dear Savesh,
Despite my research I can't find the origin of the developments implemented for this specific element. So I can't really tell you how to use the "transverse defocal" parameter because I don't know anymore. In any case, here we only use it to produce voltage changes in low energy lines with 0 in this parameter. For Enzel lenses I always advise users to use field maps instead.
