I have a problem which is following:
Cannot open : C:/Users/ardau/OneDrive/Belgeler/DTL_design/Examples/Tmp/CEL01.SFO, (No such file or directory)
->[CELL] : Segments reading
->[CELL] : Run DTLFISH
->[CELL] : Cell calculation
Although I have PoissonSuperfish with version 7.19, it did not work. I reinstalled it and tried it again. After that, I checked the directory of the Superfish in the GenDTL which was fine, but the problem still exists somehow.
Could you help me with this issue?
Arda Unal
CEL01.SFO file
Re: CEL01.SFO file
Dear Arda,
If you are sure that GenDTL has found your SF distribution, then the problem may be with the SF version.
I only have 7.12 so maybe there is a difference with 7.19.
Would it be possible to send me a zip file containing the following files:
- DTLDISH.EXE
- MDTFISH.EXE
- SF.INI
- SF95.PRF
- SFO.EXE
- DTLDISH.EXE
- MDTFISH.EXE
- SF.INI
- SF95.PRF
- SFO.EXE
Re: CEL01.SFO file
Sure! But I could not find a way to send you it in this forum, so I will share it via this link:
https://drive.google.com/file/d/11wlJwY ... sp=sharing
Thank you very much for your time and interest.
Arda
Arda
Re: CEL01.SFO file
Dear Arda,
The SF version was not the problem.
I fixed it, please upgrade your code and check again.
Let me know.
PS: "Attachements" tab-sheet at bottom of topic editor, allows to attach file.
Let me know.
Re: CEL01.SFO file
I appreciate your help, but I am not able to upgrade my software. It says that no connection to the update server. Is it a temporary problem?
Arda
Arda
Re: CEL01.SFO file
Dear Arda,
No problem with the server on my side.
Could you show me a picture of this message and the "About" box in the "Help" menu?
Re: CEL01.SFO file
I just requested a new GenDTL.exe file. Now it works completely fine.
Arda
Arda
gwhitlock68 - Neophyte
Re: CEL01.SFO file
anyone else had GenDTL just refusing to see the update server, or was that a one off thing on his end?
