Long wait in using nogui
ChinaDreamer
Post by ChinaDreamer »
Dear Didier:
When I use the nogui.exe, it always takes a long time, and then it prompts:
Qt: Untested Windows version 10.0 detected!
QProcess: Destroyed while process ("pscp.exe") is still running.
However, after waiting for about 20 seconds, it still produces the correct results. Is this due to compatibility issues with Windows 10?
The gui and nogui I downloaded should be the latest versions.When I test using a much older version, I don't encounter this issue.
Thank you very much.
Li
Re: Long wait in using nogui
Dear Li,
Don't worry about the message about Windows, it's just an unnecessary warning, the code works normally up to Windows11.
The other message is actually the cause of your problem and is fixed in the new version available on our site.
ChinaDreamer
Dear Didier:
I have download the new version, and the terminal doesn't show "QProcess: Destroyed while process ("pscp.exe") is still running". And the waiting time went from 20s to 5s. Is this normal?
Li
Dear Li,
It can actually take 5s if you haven't put in the activation key with the code, especially if you're not connected to the extern network.
