I'm having issues when running error studies on a linux computing cluster.
These are the steps I follow:
1) I connect to a computing node that has reserved 50 cores for my job.
2) In the list of computers in the 'Errors'-tab I just have the Local (0.0.0.0) computer selected with 50 cores.
3) I start the error study.
Now from time to time the study finishes without any issues, but most of the time I get the following segmentation fault:
*** Error in `TraceWin_noX11': double free or corruption (out): 0x00007f029c0049e0 ***
Critical system error: Abnormal termination (abort).
It seems like a memory-related issue, but how to circumvent this?
When I run the same routine with the GUI ('TraceWin'), I don't have this problem.
Kind regards,
Lennert
Lennert.dk
- Neophyte
Belgium (be)
Re: double free or corruption
Dear Lennert,
I've carried out a few similar tests on my own without observing this type of error. So it's probably due to your configuration that I don't know about, or some options in your projects. Could you send it to me if it's not too complicated ?
But I've noticed display problems with the Linux version, which I've corrected and put on the site.
Lennert.dk
- Neophyte
Belgium (be)
The files are added in the attachment (field maps exluded). Cheers, Lennert
Lennert.dk on Wed 11 Dec 2024 10:19, edited 1 time in total.
Dear Lennert,
In similar configurations I've never had any problems, so maybe it's down to your project, but I can't test it without the field map files!
Lennert.dk
- Neophyte
Belgium (be)
You can find the field maps in the attachment. Thanks in advance! Kr, Lennert
Lennert.dk on Tue 10 Dec 2024 18:29, edited 1 time in total.
Dear Lennert,
I've fixed the bug that caused the noX11 version to crash, but the GUI version is normally affected too, although it seems more stable.
Lennert.dk
- Neophyte
Belgium (be)
Cool, thanks! Kr, Lennert
