Steerer statistics
Steerer statistics
I am getting unexpected results when trying to obtain the statistics of an error study with sterrers. I have the file (attached), but when I try to plot both curves for Bx-By, only one of them is represented, and if I try to plot the distribution of By, I get an error. I may be making a mistake, but several months ago I obtained the correct results with this tool.
Re: Steerer statistics
Dear Pedro,
Using your file and others, I don't observe the error you mention.
So perhaps update your code to resolve the issue, and if that doesn't change anything, please be more specific about your error and the conditions that cause it.
Dear Didier
I am using the latest version of Tracewin (2.25.2.7).
The problem I am experiencing is when I try to plot the steerers values in an error study. I am attaching a screenshot where you can see that when I select the two-curve representation of the Blx and BLy values, only one curve is plotted. I have verified that this curve corresponds to Blx.
Similarly, when I try to represent the distribution of the steerers' values for Bly, I get an error, which does not occur when I try to represent Blx (I have also attached screenshots).
- Captura de pantalla 2025-12-02 100345.png (38.55 KiB) Viewed 2360 times
- Captura de pantalla 2025-12-02 100409.png (89.93 KiB) Viewed 2360 times
- Captura de pantalla 2025-12-02 100425.png (86.17 KiB) Viewed 2360 times
Dear Pedro,
I see now.
It's fixed in the last release.
I see now.
