Field Map Cavities Errors on Ex; Ey; Ez
Italycomunian
Italy
Contact:
Post by Italycomunian »
In TraceWin, it is possible to include errors in the cavity-field, from a field map, amplitude (E), expressed as a percentage.
However, in superconducting cavities, effects such as thermal deformation may also modify the relative contributions
of the electric-field components (E_x;E_y;E_z), without simply changing the overall field amplitude.
Is it possible to include this effect in the error study by introducing independent relative weights for the three components, for example
E=a_1*E_x;a_2*E_y;a_3*E_z,
with a relative normalization such as
a_1^2+a_2^2+a_3^2=1,
while retaining the existing global field-amplitude normalization through (E_0)?
In other words, the global amplitude error would still be controlled by (E_0), as it is currently,
while additional errors would modify the relative distribution among E_x; E_y; and E_z.
Re: Field Map Cavities Errors on Ex; Ey; Ez
Dear Michele,
At present, the error Ez is defined as E = Eo(1 + Err). Err is defined as a random value between [-Err; +Err]. I could envisage adding two parameters, Errx and Erry, to the error definition commands, but how do you think the random selection should be carried out?
Italycomunian
Italy
Contact:
I understand that introducing independent relative errors on Ex, Ey, and Ez may be difficult.
A simpler possibility could be to introduce a random angle theta that modifies the transverse field components as follows:
Ex' = Ex cos(theta) - Ey sin(theta)
Ey' = Ex sin(theta) + Ey cos(theta)
Ez' = Ez
The applied field would then be:
Eapplied = (1 + Err) (Ex', Ey', Ez')
This transformation preserves the transverse field magnitude:
Ex'^2 + Ey'^2 = Ex^2 + Ey^2
and therefore also preserves the total field magnitude before applying the existing global amplitude error.
The random angle could be selected in the interval:
-theta_max <= theta <= theta_max
Would this be a reasonable and sufficiently simple implementation?
You need only to add a new error parameter theta.
Michele
Dear Michele,
I think it should be possible, provided I have a look at the current code structure. It might involve more complex development work than expected.
That said, I promise to look into it when I get back, because I’m on holiday from now until early September, so I’m afraid, but sorry, I won’t be able to do anything before then.
Dear Michele,
Ok I did your proposal, have a look on manual about "ERROT_CAV_XXX" syntax and let me know
Italycomunian
Italy
Contact:
I suppose that theta input error parameter is express as radiant. Is this correct ?
Italycomunian
Italy
Contact:
I've observed that "theta" is not reported on the errors setup for the Cavity.
Dear Michele,
It’s degrees, and no, I haven’t planned to add theta in the ‘Error setup’, it’s not an additionnal error, just a different way of applying the field amplitude error.
Francegwhitlock68
Post by Francegwhitlock68 »
Didier, makes sense to me that theta stays out of the error setup... it's not a new error, just the same amplitude error applied differently, so listing it there would only confuse folk. Reminds me of fiddling with the tracking on my Defender, mate. The angle's just how the thing's sat, nobody calls it a separate fault. Might be worth a line in the manual saying it's degrees though, as Michele guessed radians and I reckon alot of people would do teh same. Cheers for sorting it so quick after your holiday 🙂
