Field map implementation
RussiaVyacheslav
Russia
Re: Field map implementation
Post by RussiaVyacheslav »
does any 'synoptic' button exist to plot arrangement of field maps in (x,y) plot?
It is needed in order to control location accuracy of field maps in space.
Dear Vyacheslav,*
No, and the only thing I could imagine would be to draw and orient the field_map in the synoptic graph using the data from the SUPPORPOSE_MAP and SUPPERPOSE_MAP_OUT commands. And of course that wouldn't help you.
RussiaVyacheslav
Russia
why is zero electric RF field on field map viewer?
Data in the field files are in MV/m.
On more addition about notation on the plot: Electrique->Electric.
TEST.rar
(5.64 MiB) Downloaded 357 times
Dear Vyacheslav,
It's because you set 'ke' parameter to '0'
And thank you, I have corrected the spelling error you noted (next version)
RussiaVyacheslav
Russia
Am I right that Ez(x,y,z,t)=Ez(x,y,z)*cos(omega*t-kz*z), where Ez is the field map data value is a correct expression for the right-side of z-motion equation?
What is 'kz' ?
RussiaVyacheslav
Russia
kz=2*pi/beta*lambda - longitudinal propagation factor (wave number)
Ok, so, I agree with your expression
RussiaVyacheslav
Russia
why does Linac Energy differ from Beam one?
What does Linac Energy mean? Is it energy of the synchronous particle?
Is the beam energy is the mean value on the all particle energies?
How can I change synchronous particle phase? Just using SET_SYNC_PHASE before FIELD_MAP and put the third parameter equals to the desired synchronous particle phase or by means of SET_BEAM_E0_P0?
One more question. How do I plot/visualize graphs of the existing and calculated project after shutdown on the TraceWin and the following restart of it without recalculation/treatment of the project?
Dear Vyacheslav,
Linac: corresponds to perfect particle transpor in perfect linac
Beam : is real beam including average beam centroid and linac errors
So, your plot, it's envelop result of a beam where you set an phase centroid errors, it's why beam curve is not simillar to "linac" one
To change synchronous phase the first way is to change by hand the RF phase or lets code do it itseft, using SET_SYNC_PHASE
And your last question: perform 2 runs with or without matching options.
