structure file emptied during run?  [SOLVED]
Norwayyngvelevinsen
Norway (no)
Norway
Post by Norwayyngvelevinsen »
I just updated to 2.17.5.3 and I see that the structure file lattice.dat and lattice_2.dat are not written in the calc directory anymore. The latter I now find in the running folder instead. However what I also find is that our structure file is now basically empty, just having a header with the info about the tracewin run/version?
lattice_after.dat
(246 Bytes) Downloaded 423 times
project.ini
(30.88 KiB) Downloaded 347 times
lattice.dat
(1.21 KiB) Downloaded 399 times
Re: structure file emptied during run?  [SOLVED]
Hi Yngve,
It's fixed.
Norwayyngvelevinsen
Norway (no)
Norway
Thank you for the prompt response as always!
