For particles with Z > 1, TraceWin appears to incorrectly compute the beam power. Please see the attached files. When I use 20 mA of 50 MeV protons, I get 1 MW of beam power. I find this value under the "Beam data" menu on the "Main" sheet. When I change to Alpha (Z = 2) I still get 1 MW of beam power. I guess that TraceWin is using P = I*V when it should be using P = I*V/Z, where Z is the number of elementary charges of the particle.
I am currently running version 2.16.6.13 of TraceWin.
TraceWin appears to incorrectly compute beam power
- basic_oct.dat
- tracewin lattice file
- (104 Bytes) Downloaded 423 times
- basic_oct.ini
- tracewin input file
- (30.88 KiB) Downloaded 387 times
Re: TraceWin appears to incorrectly compute beam power
Dear Foshea,
You are perfectly right, the error is fixed and you can upgrade your code if you want.
