Lately I get this error message sometimes during PARTRAN optimizations.
PLOT_DST number limited to 500
From->[PARTRAN] Library
From->[PROCESS_ENVELOPE] : Run PARTRAN
From->[PROCESS_ENVELOPE] : Run multiparticle program
It happens only sometimes and I cannot find the reason.
Once it has happened, I cannot continue with the optimization until I restart TraceWin.
It happened at step #250 although the limit of iterations was set to 500 for multiparticle in the 'Matching' tab.
Thank you in advance for your assistance.
PLOT_DST limit error
- Total criteria.png (6.48 KiB) Viewed 6336 times
- PLOT_DST error.png (33.57 KiB) Viewed 6336 times
Re: PLOT_DST limit error
Dear Emo,
I think I've found the problem, but I'm not sure because I don't know exactly what you are doing. Before I put a new corrected version online, I would like to see your project if it is possible for you. Could you post your project files, *.dat and *.ini
Thank you for the fast reply.
Apparently two of my collaborators experienced similar problems.
Here are the .ini and .dat files.
I am afraid I made some changes in the TraceWin settings after the error showed.
I hope it will not make it difficult to find the source.
Thank you in advance.
Emil
Emil
Dear Emo,
Thank for your project files.
Ok, problem is now fixed in the new TraceWin version available. So please upgrade your code.
