Diagnostic in same position warning  [SOLVED]
Norwayyngvelevinsen
Norway (no)
Norway
Post by Norwayyngvelevinsen »
I just got a warning about diagnostic being in same position. I suppose this is a configuration issue on our part, but I was thinking it would be useful to see e.g. the diagnostic id number in the error message to make it easier for the user to find and fix maybe?
I can also add that I produced the error because I had cut our lattice and there was no BPM after the last cavities which had a TUNE_CAVITY in front. So the more precise error message I think would be to say that there is no downstream BPM in this particular case.
Re: Diagnostic in same position warning  [SOLVED]
Dear Yngve,
As usual you are perfectly right this message is really not usable. An improvement is proposed in the latest version of TraceWin.
Norwayyngvelevinsen
Norway (no)
Norway
Thank you Didier, just tested the updated error message and now it is easier to understand :)
