I just updated to 2.17.5.3 and I see that the structure file lattice.dat and lattice_2.dat are not written in the calc directory anymore. The latter I now find in the running folder instead. However what I also find is that our structure file is now basically empty, just having a header with the info about the tracewin run/version?
structure file emptied during run? [SOLVED]
yngvelevinsen - Initiated
Norway (no)
- lattice_after.dat
- (246 Bytes) Downloaded 295 times
- project.ini
- (30.88 KiB) Downloaded 237 times
- lattice.dat
- (1.21 KiB) Downloaded 271 times
Re: structure file emptied during run? [SOLVED]
Hi Yngve,
It's fixed.
It's fixed.
Norway (no)
Thank you for the prompt response as always!
