No GUI with Fedora 40  [SOLVED]
FranceEmmanuel
Post by FranceEmmanuel »
Since I upgraded Fedora to version 40, the GUI doesn't appear. There's no error message.
I ran it with valgrind and the options "-s --leak-check=full --show-leak-kinds=all". The log file is attached.
Emmanuel
tracewin20241008.log
(11.66 KiB) Downloaded 668 times
Re: No GUI with Fedora 40
Hi Emmanuel,
As usual, what doesn't work for you works for me, making it difficult to correct what does work. :D
Image collée.png (326.82 KiB) Viewed 8620 times
FranceEmmanuel
I'd like you to post the file where the results of the following command will be stored :
sudo yum list installed > listinstalled.txt
Thank you in advance.
Emmanuel
Dear Emmanuel,
Voici le fichier demandé
listinstalled.txt
(188.45 KiB) Downloaded 693 times
FranceEmmanuel
Re: No GUI with Fedora 40  [SOLVED]
A quick update to give the solution to this issue, following a discussion with Didier.
Under linux, TraceWin generates configuration files in the directory $home/.config/CEA; In this directory, there was a .conf file named : TraceWin.conf.143948.
Once this file deleted, TraceWin opened up as it usually does.
So problem solved.
Emmanuel
