Currently, I am using the element "Multipole" to simulate as a kicker. I want to make an error study (similar to a Quad error) of the multipole (KICKER).
Do you have a suggestion on how to implement static error in the multipole?
Thanks for your help and time,
Error studies in multipoles
Re: Error studies in multipoles
If your multipole is defined as a magnetic element, you can normally use the usual command ‘ERROR_QUAD_XXX_XXX’ to apply error amplitudes.
Thank you very much for your help,
