calculating periodic phase advance from TraceWin.output
ChinaDreamer
Post by ChinaDreamer »
I want to calculate periodic beam phase advance from TraceWin.output, but I couldn't calculate the correct result. I have put the relevant details in the attachment.
Li.
phase_advance_question.docx
(16.54 KiB) Downloaded 9 times
Re: calculating periodic phase advance from TraceWin.output
Dear Li.
I understand your problem, but it’s too complicated to solve without your project files.
Could you please send them to me, including the field map file?
ChinaDreamer
this is my project files.
test_pa.rar
(357.41 KiB) Downloaded 6 times
regards,
Li.
Dear Li,
I fixed a bug about phase advance in tracewin.out file when FIELD_MAP element is used.
Upgrade your code.
ChinaDreamer
Thank you very much. After testing, I found that the results are now correct.
regards,
Li.
