I get a very strange results from the attach DTL.
May oyu explain why I get TTF > 1 ? During the SuperFish calculations the TTF <1 it is aroud 0.6.
When I plot the results T I get around 1.2.
The used particles mass is 3726.422 MeV the q=2 (Alpha particles)
TTF > 1 on GenDTL
comunian - Initiated
- Contact:
TTF > 1 on GenDTL
- Wrong TTF!
- transit time factor.jpg (46.3 KiB) Viewed 78890 times
DTL.zip- (5.66 KiB) Downloaded 1475 times
Re: TTF > 1 on GenDTL
Dear Michele,
Could yo give me your GenDTL.ini file.
- Contact:
I've put the GenDTL.ini file. In my opinion the problem is connect to the particle mass definition.
Michele
Michele
- Gen_DTL.ini
- (15.66 KiB) Downloaded 1444 times
Dear Michele,
Yes, clearly you're rigth and inded that was a charge 'q' missing somewhere.
Ok it's fixed now.
Please think to notice "Resolved" in in forum topic fixed.
Ok it's fixed now.
- Contact:
Re: TTF > 1 on GenDTL : SOLVED
thank you!
thank you!
glad that got sorted, missing charge somewhere is a right pain to spot. had a similar daft bug once where it was just a sign error, took ages to find lolcomunian wrote:thank you!
