Export error
Vyacheslav - Initiated
Export error
some error occures when I tried to save data from ZZ', XX' and YY' scatter plots into ASCII txt files.
What is it?
Regards, Vyacheslav.
What is it?
- toutatis_error.jpg (475.48 KiB) Viewed 28415 times
Re: Export error
I am Romuald, the Toutatis developer. I am currently on vacation and will look at the issue early next week. I promise.
Re: Export error
By the way, the time for me to fix this, there is a work around with the 'RFQFINISH z' command that asks to the code to end the simulation when the beam has reached z, z is in meter. The code will export a .dst file at this location. Once you got your .dst file, Plotwin can help for further treatment including export in ASCII.
Re: Export error
OK. I found the problem. Toutatis with the fix will be updated on web site by next week.
Best
R
Best
R
Re: Export error
thanks.
thanks.
Re: Export error
will Toutatis code be updated this week?
Re: Export error
It takes more time unfortunately as we have also to update all versions of Toutatis for Windows, MacOs and Linux. However, if you use Windows, I can help you by sharing 2 files you would have to download and install at a specific location (bin directory). Would it help?
Re: Export error
yes, please share your files, it will not a problem for me to install it.
Regards, Vyacheslav
Regards, Vyacheslav
Re: Export error
please find below a link for uploading the 2 files. Unzip and install the files in Toutatis/bin folder. For being on the safe side, maybe you should save your current files in a separate folder in case these new ones put you in trouble. At least, I can confirm that the fix works on my platform.
https://wetransfer.com/downloads/a8e883 ... 311/f9932a
I think that the link will expire in one week.
Re: Export error
unfortunately with the fixed files programs cannot perform correct calculations.
Please, look at the attached files. Without fixed files it is obtained fig.1. What is a problem in and how fix it? With the fixed files it was obtained the result shown in fig.2. What can you advise me?
Vyacheslav.
Vyacheslav.
fix_bad.zip- (424.3 KiB) Downloaded 938 times
