I want to calculate periodic beam phase advance from TraceWin.output, but I couldn't calculate the correct result. I have put the relevant details in the attachment.
Li.
calculating periodic phase advance from TraceWin.output
- phase_advance_question.docx
- (16.54 KiB) Downloaded 122 times
Re: calculating periodic phase advance from TraceWin.output
Dear Li.
I understand your problem, but it’s too complicated to solve without your project files.
Could you please send them to me, including the field map file?
this is my project files. regards,
Li.
Li.
Dear Li,
I fixed a bug about phase advance in tracewin.out file when FIELD_MAP element is used.
Upgrade your code.
Upgrade your code.
Thank you very much. After testing, I found that the results are now correct.
regards,
Li.
regards,
Li.
gwhitlock68 - Beginner
Glad it's sorted, Dreamer... only thing I'd add is rerun any older FIELD_MAP projects you did before the upgrade, cos the old output files will still have the dodgy phase advance numbers in them. I learnt that one the hard way, spent a week comparing against an old file and wondering why nowt matched, bloody daft.
